Just picked up a 90 GTA, no power?
Old Aug 13, 2010 | 09:27 PM
Rons91Bird's Avatar
Car: 1990 GTA, 75' Formula 400
Engine: 305 TPI, BB400
Transmission: Automatics in Both.
Axle/Gears: 2.73 in the GTA, soon to be 3.42
Hi, everyone. I recently brought home a 90 GTA 305 TPI. Was told that the motor was pulled, replaced some gaskets, oil pump, water pump, timing chain, and added headers ( flow-tech) I was told the timing needed adjustment, and that the 02 sensor was not put into the header, that i needed to mount an 02 sensor because the engine light would come on after driving a few minutes, which it does.
The car starts fine and seems to idle ok, But when i get on it, it seems to be bogged down. From say 50 mph, i put my foot into it, it drops down a gear but does not have any strong surge forward. From a dead stop, if i put my foot into it, it lazily goes forward, no chirp, no quick surge forward.
Any suggestions?
Thanks one and all for any and all help.
Old Aug 14, 2010 | 12:03 AM
Rons91Bird's Avatar
Re: Just picked up a 90 GTA, no power?
Timing and 02 sensor?
Old Aug 16, 2010 | 06:01 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
start w/ your 02 sensor. then check for codes, then set your timing with the est disconnected to 6 degrees btdc.
Old Aug 16, 2010 | 06:03 PM
ninetyone's Avatar
Axle/Gears: 3:42
wait a min, did you say gta tbi? never heard of one,anyway if you have tbi,set timing to 0 degrees
Street Lethal
Apr 30, 2019 12:14 PM
87 camaro iroc
Jun 24, 2016 06:06 PM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
gta90
Sep 15, 2015 04:00 PM
stalkier
Aug 21, 2015 01:54 AM
