85 corvette tpi 350 swap
Old Aug 13, 2010 | 10:08 PM
tonymemphis's Avatar
Hello all I have a problem,after me and a buddy swapped a 305 to corvette 350 tpi the engine idles pretty good and starts on the first turn pretty much and the swap went great the problem is when we give it gas it stalls and gives no power upon checking vaccum lines, grounds ,etc we found I guess a bad fuel injector I moved the injector slightly and gas spewed out the top of it now I moved the others and they didn't do the same thing so is this my problem or do I have to look elsewhere also what's the symptoms of a bad knock sensor or Maf sensor any help is greatly appreiciated thanks
Old Aug 16, 2010 | 06:05 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: 85 corvette tpi 350 swap
bad knock sensor symptoms are like what you described, no power. check for codes
Old Aug 16, 2010 | 06:06 PM
ninetyone's Avatar
Axle/Gears: 3:42
also 305 and 350 knock sensors are different as is the proramming in the ecm, switch prom out for a 350 trans am prom
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
