Back firing under load
Old Aug 14, 2010 | 08:50 AM
Ivelostcontact's Avatar
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
Ok, for some reason My car started backfiring under load. It ran perfectly before I went to work. Came home 20 days later and it has an issue. The car backfires out the carb bad when I give it more than a quarter of a throttle. Initially I thought this was timing so I checked it. It's set and 5 degrees advance. So I ruled that out. Could it be something with the carb? Like the power valve or something. Carb is a holley 670 street avenger, car is a 94 l69 305 with a B&M 144. I thought it may have been the S/C to base gasket replaced it. Same thing happening still. Could a loose ground cause this problem maybe?
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
86White_T/A305
Aug 17, 2015 12:16 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
