rearend swap
Old Aug 16, 2010 | 07:42 AM
AKATDOG's Avatar
Car: 84 Z28
rearend swap
just did a ls1 rear swap on my 84 z28, it looks like the driver side tire is sticking out maybe 1/4 inch more than the passenger side... will a panhard bar fix this? do i need single or double adjustable?
Old Aug 16, 2010 | 11:28 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: rearend swap
single adjustable is fine. did you lower the car when doing the swap (ie lowering springs)? In theory shouldn't have changed unless you lowered the car, but anything is possible. did you remember to install the rubber spring isolators on top of the springs? if you used the 4th gen isolators that would have lowered it a bit from what I read maybe.
Old Aug 16, 2010 | 01:36 PM
AKATDOG's Avatar
Car: 84 Z28
Re: rearend swap
the car was already lowered before the swap but now with the ls1 rear and 245 tires the driver side sticks out past the body of the car not even half inch but the passenger side is almost even so i only need a 1/4 adjustment to even it out...
Old Aug 16, 2010 | 02:31 PM
Car: 1992 RS
Engine: Carbed 350
Re: rearend swap
You'll be fine with a single adjustable end I'm sure. I've been running an Edelbrock one on my car now 4 years with no issues. Maybe a pricier brand or double ended job is better for the strip or autocross or something (I'm not a racer), but the less expensive Edelbrock has been fine for me on my street car.
Old Aug 16, 2010 | 03:54 PM
AKATDOG's Avatar
Car: 84 Z28
Re: rearend swap
ok, so will the panhard bar be able too push the rear over?
Old Aug 16, 2010 | 04:37 PM
Car: 1992 RS
Engine: Carbed 350
Re: rearend swap
Yes - an adjustable one will - you just adjust it centered, tighten the nut, and done. It's real easy to adjust, you can do it with the car on the ground.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
