Whining noises
Old Aug 16, 2010 | 07:35 PM
nateg's Avatar
Car: 89 Camaro Iroc-Z
Engine: 383 Stroker
Axle/Gears: 3:27
Whining noises
I've got a 350 TPI and as soon as I start the engine it starts whining pretty loudly, not horribly loud but all of my belts are fine with the exceptions of a little crack here and there, nothing huge, and was wondering if it's just a cold belt or what the issue could possibly be.
Old Aug 16, 2010 | 08:18 PM
GeneralLC's Avatar
Car: 1987 Camaro Sport Coupe
Engine: None
Re: Whining noises
It's possible you're low on power steering fluid, in which case it'll be especially noisy when turning the wheel. If not then try to hear if it's coming directly from the alternator; if that's the case then it's probably on its way out.
Old Aug 16, 2010 | 09:44 PM
nateg's Avatar
Engine: 383 Stroker
Axle/Gears: 3:27
Re: Whining noises
Maybe it's just normal who knows cause it's not coming from the alternator and the power steering fluid is fine, I'm guessing cold belt in the morning
Old Aug 20, 2010 | 06:48 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: Whining noises
Could be your ps pump is bad full or not.
Old Aug 20, 2010 | 07:25 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Whining noises
Maybe it's my wife - she whines alot some days!
And I wouldn't be surprised if you could hear it there!
Old Aug 20, 2010 | 08:30 PM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
Re: Whining noises
may be front pump in the trans starting to make noise check your tranny fluid.
Old Aug 20, 2010 | 09:05 PM
Re: Whining noises
I have been told both can be fixed by a mechanic..
Old Aug 20, 2010 | 09:31 PM
jake66's Avatar
Re: Whining noises
check the water pump as well the berings will start to whine when its on its way out loosen the belt and try to shake the shaft back and forth if it moves at all replace it it ain't but luke 20 bucks
Old Aug 20, 2010 | 09:49 PM
Re: Whining noises
It is noisier when you turn the wheel??
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
thejimsterz28
Sep 30, 2015 08:52 PM
Youngs92
Sep 23, 2015 11:29 AM
