car overheating?
Old Aug 19, 2010 | 03:45 PM
fallen0kashi's Avatar
Car: 89 z-28
Engine: 388
Axle/Gears: 3:42
car overheating?
I have 89 Iroc 5.7and to sum tings up I have had everything done except having the fuel injectors changed. After awhile of driving when u come to a stop the car will either die or sputter and catch itself and I need some cause I don't know what's wrong
Old Aug 20, 2010 | 07:29 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: car overheating?
More than likely you have one or more bad injectors. Use a multimeter and test for ohms. Test each injector with the key on and engine off. Just put the probes of the multimeter into the top of each injector where the two wires go into each one. You should end up with something like 0.013 to 0.018 or so with each one. If you get to one that is like 0.003 , it is bad. If you replaced everything else then you prob have a bad injector.
Old Aug 20, 2010 | 07:30 PM
ninetyone's Avatar
Axle/Gears: 3:42
oh and you should replace all of them at the same time,not just the bad one.
Old Aug 20, 2010 | 07:43 PM
Car: 89 z-28
Engine: 388
Axle/Gears: 3:42
ok thanks i will post after i check them
Reddeath210
Oct 6, 2015 08:20 AM
mustangman65_79
Sep 1, 2015 03:51 PM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
