Spark Plug Boot Guards -- Won't fit MSD?
Old Aug 20, 2010 | 02:02 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
I recently wound up buying two sets of spark plug boot guards for my T/A. The only problem is, I can't get them to fit over my MSD spark plug sires. One set is the mesh with the steel ring and the other set is the reflective cloth. Both are supposed to fit over the wires where the boot plugs into the spark plug but I can't get them to fit. I know I've seen them on cars but for the life of me I can't figure out how to install them! Any help would be appreciated.
Old Aug 20, 2010 | 08:12 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Spark Plug Boot Guards -- Won't fit MSD?
Are the MSD wire boots hard? ( as in not flexible?)
My Accel 300 wires have flexible rubber boots and I maneuvered the plug wire through the guards by sticking a screwdriver through the guard into the plug boot and steering wire back through
The 90 degree plug boot flattered out to like 120 with the screwdriver in the end so it went through easy
Old Aug 20, 2010 | 08:18 AM
Twin_Turbo's Avatar
Pull the boot off, slip wire through sleeve and reinstall boot.
Old Aug 20, 2010 | 09:10 AM
Ozz1967's Avatar
Car: 1984 Trans Am
The boots come preassembled, can I do that without damaging the wire ends inside the boot?
Old Aug 20, 2010 | 02:10 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
How about photo(s) or a part number/link so we can see what we're dealing with?
Jake
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
Bryan F
Aug 18, 2015 02:28 PM
