92 camaro non-start
Old Aug 23, 2010 | 02:21 AM
jaebell's Avatar
Car: 92 chevy camaro rs
92 camaro non-start
well heres my story i have a 92 camaro 305 engine that i cant get to run. my problem is when i turn the key fuel pump pumps, injectors spray but no start. now if i spray quick start or pour gas in carburator she fires right up no problem but wont stay running even holding the gas pedal, then when the car gets ready to shut off injectors spray but engine still stops. i have change fuel pump, fuel injectors, fuel filter and some round sensor thing on side of throttle body. can someone please tell me my next step to get this car running
p.s. dont know if this means anything but all gauges go all the way over to right when trying to start and also my ignition is bypass with a push button
Old Aug 23, 2010 | 03:20 AM
alexisgreene's Avatar
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
Re: 92 camaro non-start
Ignition bypass? Do you have a wiring diagram of how it is tied into the circuit? I am willing to bet money this is the source of your problem if the VATS has not been properly addressed. Your gauges going all the way to the right is a definite sign that something is wrong electrically.
Old Aug 23, 2010 | 04:55 PM
jaebell's Avatar
i dont have a diagram but its a simple bypass, 2 wires going to the starter connected to a button. i have to turn the key to the run position then hit the button to start. im thinking its possibly my computer ,is there any way to check a computer?
Old Aug 23, 2010 | 05:05 PM
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
Computer problem can happen but are VERY rare. Have you verified that you have spark? When you connected your starter to the push button, did you disconnect it from everything else it was originally hooked up to? How long have you run the car with it that way?
Remember there are 3 things an engine needs to run... fuel, compression, and spark. You already verified the fuel so make sure you have spark and go from there.
Old Aug 23, 2010 | 05:10 PM
jaebell's Avatar
i been running it that way for about two years and yes i disconnected everything else. i have spark cause like i said if i pour gas in the carburator it runs fine til i stop pouring
Old Aug 23, 2010 | 05:33 PM
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
When you say carb you are refering to the TBI unit, right? Have you checked fuel pressure at all before changing parts?
Old Aug 23, 2010 | 07:27 PM
jaebell's Avatar
yes tbi unit, havent check fuel pressure before or after changing parts, how much prssure should i have
Old Aug 23, 2010 | 08:44 PM
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
13 psi if i am not mistaken
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
