Low Vacuum
Old Aug 24, 2010 | 02:16 PM
gmanuel's Avatar
Low Vacuum
checked the vacuum at the carb and it was low. Around 10lbs. I have checked all vacuum lines and connections. If I place my hand over the carb. the engine speed increases and the vacuum climbs up to almost past 15 lbs. What should I check next?
Old Aug 24, 2010 | 02:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Low Vacuum
The engine was warm when you tried this? Check your idle mixture.
Old Aug 24, 2010 | 04:14 PM
gmanuel's Avatar
Re: Low Vacuum
Yes the engine was warm. Adjusting idle mixture has very little affect.
Old Aug 24, 2010 | 04:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Low Vacuum
How did you adjust the mixture? What kind of carb is this?
Old Aug 24, 2010 | 04:21 PM
gmanuel's Avatar
Re: Low Vacuum
It is the 4 barrel stock quad. jet. I adjusted the idle screws at the base with the engine idle low and the distributor advance disconnected and capped
Old Aug 24, 2010 | 04:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Low Vacuum
How far did you adjust them? What direction? What were you looking for while you adjusted? Is this a CCC Qjet, or no?
Old Aug 24, 2010 | 04:29 PM
gmanuel's Avatar
Re: Low Vacuum
It is not computer controlled. One jet was able to turn in all the way and the engine still idled but was rough. The other screw would stall the engine. I turned both idle screws out two turns. I was looking for improvements in vacuum and an increase in RPM
db057
Apr 28, 2019 07:45 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
amcnellis
Sep 16, 2015 04:16 PM
adelane
Sep 9, 2015 08:51 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
