Need Houston business for vats or car alarm
Old Aug 27, 2010 | 08:48 AM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
I need to do a vats bypass tonight. Do you know any place in Houston where I can buy one? Or I have heard that some aftermarket alarms have the bypass built in. Re ommend one?
I am at work and have limited google time.
Thanks!
Old Aug 27, 2010 | 09:17 AM
Stephen's Avatar
Car: 87 GTA
Re: Need Houston business for vats or car alarm
Radio Shack & a few minutes of your time........
VATS Bypass
Old Aug 27, 2010 | 09:32 AM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
One thing - I hate my iPhone.
I tried the resister thing - the vats itself is out. Don't want to tear out dash. Would like kind that wires into ECM
Thanks for the reply
Old Aug 27, 2010 | 10:01 AM
Stephen's Avatar
Car: 87 GTA
If the VATS module is out, it'll have to be removed, replaced, or replaced for anything to work, including the bypass method I showed.
Old Aug 27, 2010 | 10:32 AM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
I was under the impression that the bypass that wires to the ECM completely bypasses the vats module. Just sends correct data directly to ECM.
Old Aug 27, 2010 | 10:44 AM
Stephen's Avatar
Car: 87 GTA
Nope. The bypass method is just a way to trick the VATS module into thinking that a VATS equipped key is being inserted into the ignition. That way you can get a $2 regular key cut anywhere, instead of buying a $25 chipped key.
It won't help you any, if your VATS module has actually gone out.
Old Aug 27, 2010 | 10:53 AM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Well, I have a good key, ign lock, and vats. Was trying to avoid changing the vats by wiring the bypass at the ECM. The location of the vats is not pretty
Old Aug 27, 2010 | 10:57 AM
Stephen's Avatar
Car: 87 GTA
Not sure what you were trying to say there. In Post #3 you said VATS was out, in Post #7 you say VATS is good. If you tried te bypass, are you sure you tried te right resistor value?
The bypass I showed is at the steering column & under the dash. No need to really remove anything.
Old Aug 27, 2010 | 11:50 AM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_5422wt_948
The link is to one that doe not need a good vats
I have good key,lock,and vats from another car
Old Aug 27, 2010 | 11:56 AM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Old Aug 27, 2010 | 01:07 PM
Stephen's Avatar
Car: 87 GTA
Interesting. Never heard of that & no idea how it would even work on neither a working on non-working VATS module.
Try it & see, I guess.....
Old Aug 27, 2010 | 01:15 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Looking for one.
Supposed to do away with need for vats as it connects to ECM at the ECM
Old Aug 27, 2010 | 01:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Moates.net Buy the chip adapter with the chip and I'll reburn your stock programming with Vats delete
Old Aug 27, 2010 | 07:08 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
got it running. the dash came out much easier than I imagined. popped it in and it cranked right up. Of course I am not mounting it back in factory position.
Old Aug 27, 2010 | 07:13 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Thanks for the offer. I'd really rather go that way but needed the car quick and I really need a custom burn bad. Had to get people to ride me to work.
I still need a custom chip burned as the overlap in my cam is causing the ecm to fight it at idle. Runs great off idle. I have some World Racing 64cc/.202s to put on it before I get a chip burned.
Thanks again.
BTW - sweet twin turbo.
Old Aug 28, 2010 | 03:51 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Car finished and running good.
I have been looking at moates.net and I think I'll have to look into buying some burning stuff.
onefreakz
May 14, 2018 12:15 PM
CRFred
Feb 7, 2016 11:39 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
AkDrifted
Aug 17, 2015 07:45 PM
djmarch
Aug 9, 2015 05:27 PM
