coolant leaking when knock sensor removed
Old Aug 28, 2010 | 02:13 PM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
ok guys this morning i removed my knock sensor because i was going to replace it cuz ive been getting code 43..but once i removed it coolant was leaking threw where the knock sensor screws on too..i have a bad feeling that this is pretty bad. what should i do to fix this is problem i seriously dnt know wat to do??... thanks in advance!!
Old Aug 28, 2010 | 02:15 PM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
Re: coolant leaking when knock sensor removed
Its normal, dont worry about it.
replace the KS, refill with coolant.
Old Aug 28, 2010 | 02:28 PM
robg91z's Avatar
Engine: 350ci TPI
hummm... i had replaced it before and not even a drip of coolant came out and it was fine for about a month or so then i started getting code 43 when the car heated up now that i was gonna try to replace it coolant started coming out and now that i turn it on the code is already there...??
Old Aug 28, 2010 | 03:36 PM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
The knock sensor is screwed into the water jacket. It will leak coolant if not that means you was low on coolant.
Old Aug 28, 2010 | 03:44 PM
robg91z's Avatar
Engine: 350ci TPI
so then my situation is fine?..its weird cuz i turn on my car and the SES light is already on..maybe theres another problem?
Old Aug 28, 2010 | 04:14 PM
built91Z28's Avatar
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
If you dont have water coming out of the block when you remove the knock sensor, you have a problem.
Is the SES light coming on when the motor is off, but the key is on? If so, that is how it is suppose to be.
Old Aug 28, 2010 | 04:16 PM
robg91z's Avatar
Engine: 350ci TPI
the SES light comes on when the motor is on
Old Aug 28, 2010 | 04:35 PM
Twin_Turbo's Avatar
It's very common that no water comes out when you screw out the sensor. It's not a problem, it's simply salts and deposits setting in that lowest part of the water jacket. If you stab the hole w/ a screwdriver the water will come out. In no way does it automatically mean you'e low on coolant. In fact, if the hole is open and no water comes out you're not low on coolant...you're out of coolant. The hole is originally a drain hole, it's the lowest point, removing the plug or sensor will drain all coolant from the block.
Old Aug 28, 2010 | 04:36 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Yeap. Same thing happened to me.
Old Aug 28, 2010 | 05:03 PM
robg91z's Avatar
Engine: 350ci TPI
oh ok i see..now my SES light comes on so i need to check wats wrong cuz the knock sensor and connector is still new
Old Aug 28, 2010 | 06:44 PM
robg91z's Avatar
Engine: 350ci TPI
is it bad stabbing the hole with a screwdriver when there isnt any coolant coming out and then u accidently stab it to hard and the coolant starts to come out? cuz im just saying cuz the SES light wouldnt come on when i would start the car before and now that this happend i pluged back in the Knock sensor in a hurry cuz the coolant was coming out and i plugged back in the connecter and then i turn the car on and the SES light was on....???
Old Aug 28, 2010 | 07:05 PM
On Probation
no its fine, and i suggest draining the coolant, and getting that junk out of there.
Old Aug 28, 2010 | 07:09 PM
robg91z's Avatar
Engine: 350ci TPI
so im guessing that was all junk clogged up.. quick question..so how does the knock sensor work if theirs coolant passing threw it inwhich where u screw it in to?
Old Aug 28, 2010 | 07:16 PM
On Probation
it senses certain frequencys, coolant has nothing to do with it...GM just got cheap, and instead of casting another hole, they reused the existing block drain holes.
Old Aug 28, 2010 | 07:20 PM
robg91z's Avatar
Engine: 350ci TPI
oh ok thanks i got freaked out this morning when coolant started coming out like crazy!..im guessing i have an electrical problem or the memcal is crap cuz the SES light doesnt go away anymore
Old Sep 4, 2010 | 12:11 AM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
you probably have a ground issue, run a tap through the hole and replace your ks pig tail. Solved my problem and I got a coolant bath too. I noticed a small drip from the hole and couldn't leave it alone so lesson learned.
bamaboy0323
Sep 3, 2015 06:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
