15th aniv. l69 sitting a long time. What to replace?
Old Aug 30, 2010 | 11:31 PM
massaku's Avatar
Car: 84 15th anniversary Trans Am
Engine: 305 H.O. L69
I have a 305 l69 engine that has been sitting for about 5 years that needs a little bit of attention. The engine runs alright but I want it to run better! sometimes when trying to start the car fuel will spit out of the carb...I am guessing this just means it needs a carb rebuild. what are some things that I should replace just because it has been sitting for a while? I am going to do a full tune up, oil change etc. going to give this car to my sister so anything that could go out needs to be addressed! thanks peeps.
Old Sep 1, 2010 | 12:01 PM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
Re: 15th aniv. l69 sitting a long time. What to replace?
fuel filter, plugs, have the plug wires checked, rebuild kits for the CCC carbs are about 20 bucks if all that is needed is gaskets. when you change the oil dont forget to add zddp additive. also after that long of a sitting check all your vacuum hoses as they will most likely have dryed out and cracked
Old Sep 1, 2010 | 10:48 PM
massaku's Avatar
OK I will replace all of those things and I will check the vacuum lines.
Thanks for the help!
specialized
Jun 18, 2022 09:26 AM
customblackbird
Aug 15, 2021 10:16 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
TheExaminer
Aug 26, 2015 04:59 PM
