Aluminum vs cast iron heads
Old Sep 3, 2010 | 05:31 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Hey guys, I am considering buying these http://www.summitracing.com/parts/TFS-30300005/
But I have a few questions.. I am running a 78 350, 2 bolt block, with flat-top 4 eyebrow pistons..
When I did my calculations for compression with a 58cc block, I had somewhere along the lines of 12:1 compression..
What I've been reading about the aluminum is that an engine with cast iron heads with 10:1 compression burning 92 octane.. That if you were to switch them to aluminum it would run like it 9:1 compression.. Is this true?
Old Sep 3, 2010 | 06:23 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Aluminum vs cast iron heads
It's the chamber size that affects the calculations.
Old Sep 3, 2010 | 07:18 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
You can get away with alittle more compression using aluminum heads rather then the Iron heads, for street car running 93 octane i wouldnt go past 11:1.
Old Sep 3, 2010 | 10:08 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Compression ratio is dependent on the physical dimensions of the parts, it doesn't have anything to do with the materials.
An aluminum head transfers heat from the combustion chamber more quickly than iron, so you need to build the engine with a little more static compression to keep the output equal.
junkcltr
Aug 2, 2019 11:12 PM
InfinityShade
Feb 21, 2016 01:29 PM
anesthes
42
Oct 24, 2015 07:30 PM
italiano67
Aug 31, 2015 06:04 PM
