Rust removal... Is this a good idea?
Old Sep 3, 2010 | 05:35 PM
85projectZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
I was looking at my block and so far I am very pleased with it! There was one thing I noticed however. The paths where the coolant flows looks kind of red or rusty-ish inside the bare block.
I was thinking of pouring some CLR (that Calcium Lime and Rust product) or something similar into the holes and shaking it up a bit to break up all that rusty looking layer within my block and then rinse it out thoroughly with water before I assemble it.
Because I'm thinking, "That stuff is just going to break off and circulate through my cooling system if I don't right?"
So is that a good idea or should I just leave it alone??????????
Old Sep 7, 2010 | 11:27 AM
Engine: 5.7 LSX
Re: Rust removal... Is this a good idea?
Hello??? Does ANYBODY have ANY input????
Old Sep 7, 2010 | 12:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it's just surface rust, I wouldn't worry about it.
Old Sep 8, 2010 | 01:35 PM
Engine: 5.7 LSX
Cool, thanks man. Would it be a good idea if it were heavily rusted?
Old Sep 8, 2010 | 01:46 PM
alexisgreene's Avatar
Car: 91 Camaro RS
Engine: 305 (L03)
Axle/Gears: Stock
I do not know the name of the product, but they have stuff made specifically to clean water passages. Just ask for it at your local parts store. It never hurts to clean em out.
Old Sep 8, 2010 | 03:02 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
cooling system flush would be what you're looking for, but what you've got there is normal. your coolant helps to keep that at bay in normal situations. once the engine's in place, run a bottle of the flush through the system to get rid of anything thats built up and follow directions (dont want it left in the system when you go to add your normal coolant)
CarGuyDennis
137
Dec 6, 2016 11:02 PM
LittleFranks
Aug 20, 2015 03:55 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
BurlyChev
Aug 16, 2015 09:08 PM
NBrehm
Aug 5, 2015 07:57 PM
