A quick cam question.
Old Sep 4, 2010 | 11:45 AM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
I have a early 350 motor. Specs are in my Sig. Its in great condition. I want a more lopey idle than stock. Right now the stock cam is in it. I want to keep in pretty mild im not looking to get new heads yet ect.
I was thinking about this cam
Camshaft, Hydraulic Flat Tappet, Advertised Duration 262/272, Lift .420/.442, Chevy, Small Block, Each\
I'm not to familiar with cams will it give me more lope/chop than my stock cam. Anymore power? i'm thinking 10-15hp?
Old Sep 5, 2010 | 10:18 AM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
Re: A quick cam question.
Lift and duration has nothing to do with a lopey idle. All that does is tell you when the valves open and how long they are open. What you are looking for is a cam with a narrow LSA (lobe seperation angle) On most all stock cams they will have one around 120 degrees thats what gives a smooth idle, what you need is one with 112 to 110 degrees. thats were the lopey idle comes in to play. But be warned with a lopey idle you will loose some of the engine vacumn the runs things like the power boster for breakes.
A good choise for cams with the "fake idle" would be the thumper cams by comp cams. But these cams still need things like a high stall converter to run right.
This cam here has a wide range in RPMs
http://www.summitracing.com/parts/HRS-CL112011/
And will give you a lopey idle, and you wont need a stall converter because its RPM range starts at 1200 rpm in most cases thats just off idle.
Old Sep 5, 2010 | 07:23 PM
Car: 1985 IROC-Z
Engine: 355
Well I will not be needing a stall converter anyway. I have a manual transmission. Im not worried about lack in brake booster power my car is a weekend warrior. I might see an hour to two hours of run time a month. Most car shows are local and I only drive it back and forth to work which is 5 miles from home.
Thanks that cam looks decent I will keep that in mind. I wasnt sure about lobe separation angle that and another article I read cleared everything up as far as cam choices. Thanks
Old Sep 5, 2010 | 08:47 PM
kd5icr's Avatar
Axle/Gears: Stock
Killer. Yeah a lot of people dont think about the LSA. Most good street cams will be a 113 or so but when you get to 111 thats about as lopey as you can get without changing a lot.Thats why I showed you the one cam it has a wide useage range and the lopey idle. There are even lower LSA's of 109 but thats to radical for a street rod unless you run a super charger.
I am just glad I could help.
Old Sep 6, 2010 | 11:19 AM
Car: 1985 IROC-Z
Engine: 355
What confused me was the summit cams. The description said 110 lobe separation and smooth idle. Other summit cams said 114 and lopey idle. which to me is backwards. I will most likely go with comp cams thumpr which i read good things about street/strip.
I went ahead and emailed comp my specs and comments about what i wanted to achieve. I was hesitant at first to email a cam company because in the past anytime I emailed an aftermarket performance company they tried to sell me on a laundry list of things to upgrade my package far beyond what I needed or wanted. I hope they don't try and sell me on upgraded valve-train and roller configuration.
neilb
Oct 4, 2018 12:36 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
