cooling fan
Old Sep 4, 2010 | 05:27 PM
triggerman454's Avatar
Car: 1991 Firebird, 1997 3000 GT
Engine: V6
Transmission: Auto... 5 speed manual
Axle/Gears: stock
cooling fan
At what temp is the cooling fan supposed to come on ?????
1991 V6 Firebird.
Temp gauge got to 210 and the fan never energized. Always ran 175 or so. Just installed new computer but it looks like the fan circuit is isolated by it self.
Any info appreciated
Old Sep 4, 2010 | 06:53 PM
Damon's Avatar
Re: cooling fan
It's way up there. Like 228* or so unless the A/C is turned on. At least the V8 cars up that high. Not sure about the V6s, although when I owned a 91 V6 Camaro I recall the needle would regularly be above the 220* hash mark in stop-and-go warm weather traffic. Never overheated, just built to run hot from the factory.
There's a tech article about the fans and their control circuits and activation temps in the Tech Articles section of this board. I've found the information in it to be very accurate over the years.
Old Sep 4, 2010 | 09:40 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: cooling fan
You say your fan does not kick on? If that is the case your fan relay may be fried.
Old Sep 5, 2010 | 08:49 AM
Engine: V6
Axle/Gears: stock
Re: cooling fan
Thanks for the reply. Am going to bypass stock relay and install an industrial relay with a variable thermistor of my choosing . This way I set the temp when the fan comes on at a specific temp. or just turn on the A/C switch since I don't use the air.
Old Sep 5, 2010 | 08:54 AM
Re: cooling fan
I rigged up a switch that grounds the temp sensor. It's the green wire that leads to your relay. I did it on both Camaros. In the heat, I run the fans constantly. I'd rather wear out a fan motor, then let the engine get hot.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
