a couple of problems
Old Sep 5, 2010 | 11:15 PM
camarokid90's Avatar
Want a title? Post!
i purchased my camaro (87 iroc) in may of this year... since then i have had problems with the floor boards, speedometer works occasionally, there is an air leak in my passanger side door, both passanger and driver side doors are hanging, and i cannot seem to find out why i am leaking oil (i have replaced the oil sending unit... it seemed to work but then started leaking again 30 min. later...) if anyone knows how to fix, control any of these problems or get me started please let me know. and just recently my hvac system quit on me i cant get any air what so ever, be it hot or cold, soo please let me know guys i love this car and just want it to run like a dream lol
Old Sep 6, 2010 | 06:29 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: a couple of problems
Originally Posted by camarokid90
...speedometer works occasionally, there is an air leak in my passanger side door, both passanger and driver side doors are hanging, and just recently my hvac system quit on me i cant get any air what so ever, be it hot or cold...
Welcome to TGO.
Speedo: https://www.thirdgen.org/forums/inte...eedo-woes.html
Air leak: Weather stripping?
Hanging: http://www.top-downsolutions.com/pro...products_id=38
HVAC: Check the motor.
JamesC
Old Sep 6, 2010 | 10:47 AM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
Just like James said, first off welcome. Second you need to go after 1 thing at a time here. First off stop the oil leak, thats a fire that is about to happen, so clean it up and look for were the oil is leaking from then you can stop that. As for the doors the car is about 23 years old, so it is more tham likely going to need new hinge bushings it stop the sag in them and new door weather seals. Those are were I would start. As for the other things, just go to the threads james told you abut. These boards have a ton of info all you will have to do is search for them. You will find it.
Old Sep 18, 2010 | 08:12 PM
thunder69n's Avatar
Car: 87 Firebird Auto V6 2.8l
any good spots to see more about oil leak. Mine is dripping outa this whole on bottom of transmission? http://www.youtube.com/watch?v=PNH7uJ-C9YQ
Old Sep 18, 2010 | 10:00 PM
kd5icr's Avatar
Axle/Gears: Stock
That does suck. It looks like the trans oil pump is leaking. As well as the tailshaft seal and the seal at were the drive shaft goes in. But for sure the pump seal.
Cleotiz
Jan 6, 2018 08:56 PM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 9, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
