runs for 3 seconds and dies
Old Sep 10, 2010 | 12:36 AM
91Camaro_RS's Avatar
my car starts for 3 seconds and then dies
has spark, fuel pump works, and timing is good
turn key runs for a few seconds and dies but if i give it gas it will run fine, but it just wont idle
Old Sep 10, 2010 | 01:15 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: runs for 3 seconds and dies
Does this problem intermittent? Mine seems to idle out and just drop too low and die.
I've cleaned, and then replaced the IACV.
Set timing.
I've replaced the entire ignition system, dizzy to plugs, sans timing chain and balancer.
I think I have a fuel problem.
Old Sep 10, 2010 | 03:02 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
hmmm. that sucks check the pickup coil resistance because if it aint firing in the correct order it aint going to idle.
Old Sep 10, 2010 | 03:53 AM
something similar happened before and it was the Ignition control module but that time it wasnt starting this time it will start but dies
I have a new dizzy, pick up coil, ignition control module, cap and rotor, coil is fairly new and coil wires are new
i dont think im losing spark i think the car is burning the gas from the prime and something is telling the pump not to pump unless i give it gas manually, so it wont idle at all
eightsixseven
Dec 16, 2024 01:50 PM
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
justin57
Aug 20, 2015 07:05 PM
