Edelbrock Carb Intake--bolt tourque cant be this low??
Old Sep 12, 2010 | 06:11 PM
zact1024's Avatar
Car: 88 Camaro
Engine: 305 TBI
It said tighten to 11ft/pds..so i did.but now when i turn the engine over by hand (havent been able to start car because of various other problems) I can hear air hissing out..can i go any tighter to try and stop it?
Old Sep 12, 2010 | 06:22 PM
Damon's Avatar
Re: Edelbrock Carb Intake--bolt tourque cant be this low??
Is it a Vortec-style intake? If so, bolt torque is very low when used with factory-style Vortec intake gaskets. It's a plastic shim with o-rings around all the ports. Only requires enough torque to compress the o-rings. Any more than that does nothing but distort and crack the hard plastic shell of the gasket.
In any case, the hissing you hear while hand-cranking the engine is air bleeding past the rings on the compression stroke and is normal.
Old Sep 12, 2010 | 06:37 PM
zact1024's Avatar
Car: 88 Camaro
Engine: 305 TBI
oh ok thanks, thought it was something I did.
and yep its vortec
theshackle
Sep 17, 2020 08:26 AM
beastin91rs
Oct 9, 2015 07:38 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
86IROC112
Aug 17, 2015 02:00 PM
GVMV
Aug 16, 2015 08:01 PM
