Temperature gauge suddenly stopped!!!
Old Sep 12, 2010 | 06:31 PM
cam.crazy's Avatar
Hi,
Today the temperature gauge suddenly stopped working. When I turn on the car, the temp. gauge goes to most right position and then it goes back to the original position and stay there.
Everything seems to be normal. The fans turns on/off while driving the car.
Is it an electical (wiring) proplem? (or)
The temp. sensor that is located between cylinders 1 and 3 has a proplem? (or)
The gauge it self become faulty? (or)
Something else..
Any idea, pls. help. as I no longer able to know the temprature of my car
Camaro RS 1991, V8 TBI
Old Sep 12, 2010 | 07:43 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Temperature gauge suddenly stopped!!!
You've already answered your own question - it's one of the 3. With the key on, take the wire out of the sender and ground it and see if the guage moves from one side to the other - if it moves when grounded, then probably bad sender. If it doesn't move, then probably bad guage or wire.
You can take a ohm tester and check continuity between the wire at the sender and the wire right before the guage under the dash - that will let you know if there's an issue with the wire.
Old Sep 13, 2010 | 06:15 AM
cam.crazy's Avatar
Thanks, I'll try it and put my feedback
Old Sep 13, 2010 | 07:10 AM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
Transmission: 700r4 stock
I believe my gauge is stuck in the down position and I don't knowhow to get it unstuck. let me know what you find out please.
Old Sep 13, 2010 | 05:41 PM
cam.crazy's Avatar
I will
Old Sep 14, 2010 | 03:52 AM
cam.crazy's Avatar
I found the cable disconnected from the the temp. sensor that is located between cylinders 1 and 3 !!!! temp. gauge back to normal..
Old Sep 14, 2010 | 03:31 PM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
cool!!!!!!!!!!!!!!
Old Sep 18, 2010 | 02:21 AM
Jaguar99's Avatar
Car: 1991 RS Convertible
Engine: 305 TBI
Camaronewbie,
I have a 91 RS and I'm having a problem with my temp. gauge. The temp. gauge starts working like normal and then slowly goes to full hot within about 5 minutes even though I know my engine is not over heating. I've replaced my sending unit and still no change. Then I bought another instrument cluster and swapped out the center section that has the temp. gauge. It still didn't fix the problem. Then I tried putting all my original gauges into the instrument cluster that I bought, again no luck. Of course then I tried putting the center portion from the instrument cluster that I bought back into the instrument cluster that I bought, put it in the car and you guest it! It still didn't solve the problem. So after doing all the swapping out and using two different instrument clusters, all I can think of is that both circuit boards on each instrument cluster's are probably messed up. If you have any idea of what I can try next to fix this problem I would surely appreciate it.
Old Sep 25, 2010 | 01:46 PM
cam.crazy's Avatar
Sorry I saw your message bit late..it's weird problem and sorry I can't help.
better to post it directly. You may get help from an expert person.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
Jlanz55
Sep 9, 2015 09:09 AM
