Help distributor advance?
Old Sep 12, 2010 | 06:47 PM
brandonA.'s Avatar
Hello where can I find the stock settings for the distributor advance curve for a 1989 305 chevy 1500 TBI automatic trans pickup?
I put this fuel injection system in my IHscout 304v8 and the curve seems to max out too soon at around 2000 rpm. So I need the stock Chevy specs.!!!!!
THis is what I found
* this is with the wire for timing disconnected!
-1000rpm= 7
-1500rpm= 17
-2000rpm= 21
-2500rpm= 22
-3000rpm= 22
Thanks,
Brandon
Old Sep 12, 2010 | 09:26 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Help distributor advance?
First this forum is for 3rd gen fbodies.
Second, the TBI motor's ignition curve is handles completely by the computer. Nothing you can change without getting a custom chip. And having the total timing in by 2000 isnt bad either.
MM2Robinson
Oct 1, 2017 09:16 AM
Zane Story
Oct 8, 2015 12:40 PM
Jorlain
Oct 8, 2015 01:57 AM
Camaro_383
Sep 11, 2015 11:28 PM
Jlanz55
Sep 6, 2015 03:05 PM
