Service Engine Light.
Old Sep 12, 2010 | 11:36 PM
91nunifb's Avatar
91 Firebird 305 tbi.
I've looked around to see if i can find an opinion to this but couldnt find anything. When im driving at night, and its pretty cool out, my service engine light will come on (i dont think its happened during the day, maybe once or twice) when I shut off the car and turn it back on the light is off. Unfortunately I dont have a code reader or the funds to get one at the moment.
The car runs perfectly fine before and after the light turns on. I just wanted to know if anyone had the same experience and if they knew what it could be.
from what I gather, it seems like a code 32. if you think it is, is it something that NEEDS to be replaced immediately? or can I drive with it for now?
Thanks in advance, you guys have been a great help to me already.
Old Sep 12, 2010 | 11:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Service Engine Light.
Staples has code readers on sale, $0.79 for a box of 100. http://www.staples.com/1-Size-Paper-...?cmArea=SEARCH
Jump pins A and B on the ALDL connector under the dash, turn the key to "on" without starting the car, and count the groups of flashes.
Old Sep 12, 2010 | 11:50 PM
91nunifb's Avatar
I was trying to figure out what it meant in the tech article on the site. I dont mean to sound to noobish, but can you explain what i need to do in layman's terms?
Old Sep 12, 2010 | 11:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Try this explanation http://www.freeautomechanic.com/diag...blecodes5.html
Old Sep 13, 2010 | 12:14 AM
91nunifb's Avatar
so i count each group of flashes as a number. so if its "flash, flash, flash, pause, flash flash" that would be thirty two right?
if im right, it is 32. is this something i should change immediately? or i can live with it?
Old Sep 13, 2010 | 12:29 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That would be 32.
Whatever the code is, you still have some work to do to find out why it's being set, but at least you'll know where to start looking.
Old Sep 13, 2010 | 12:31 AM
91nunifb's Avatar
im planning on looking all around. but i mean like i said before i realy dont have the funds to work on it. so is it something I should really worry about? or can i ignore for now?
Old Sep 13, 2010 | 12:33 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Depends on the code and the cause.
Old Sep 13, 2010 | 12:35 AM
91nunifb's Avatar
code 32. so worst case scenario on that code? (sorry if im being annoying)
Old Sep 20, 2010 | 12:30 PM
Waymores's Avatar
Car: 89 Camaro
Engine: 350 TBI
Check all your vacuum hoses for leaks, should only be about two hoses. 1 goes from TB to solenoid, the other one goes from solenoid to egr. Check your egr valve, or get a new one, then check out the solenoid, or get a new one. Total price for everything will prolly be around 100 bucks. Ive replaced all that stuff, still getting a code 32 for about a year now, and its still running fine
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
apie2546
Aug 10, 2015 05:43 PM
