Starter grinding?
Old Sep 20, 2010 | 11:51 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Starter grinding?
I'm not sure how to fix this.. Its a 1990 camaro 305, ram flywheel, jegs mini starter. I've got it shimmed so the starter sounds fine, but once every 4 or 5 starts the starter will grind. To me it looks like the starter is too far away from the flywheel, the starter gear is beginning to spin before the teeth on the starter are engaging the teeth on the flywheel. Is there any way to move the starter closer to the flywheel?
Old Sep 20, 2010 | 12:55 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Starter grinding?
Depending on the mini-starter sometimes there are shims between the starter motor and the clockable plate. If you have the mini-starter that has the adjustable plate you can mark the mounting holes for the bolt(s) remove them, remove the plate, and look to see if there is a flat shim in it.
Old Sep 20, 2010 | 02:24 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
I'll pull it off and have a look at that, thanks!
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
