new 383 i built has problems
Old Sep 14, 2010 | 05:46 PM
louflemm's Avatar
Engine Specs:
About 6 months ago i built a 383. eagle bottom end, procomp 3003 heads, 210 intake ports 2.02 1.60 valve. cam is 4.88int 5.10exh. 234 244 duration. procomp intake manifold, holley street avenger dual feed. malory adjustable FPR set to 6psi. Push rods are 100 thousands longer i think. Stock 305 exhuast manifolds and stock rocker arms. cloves double roller timing chain ngk vpower plugs.
Heres the problem:
the engine ran like **** misfiring and what not.
i took the valve covers off one day and seen the rockers were hitting the valve cover on the side not the top(i bought 20 dollar valve covers off ebay). i decided to stop driving the car. then i started to take rocker arms off. once i did this i seen the rocker was hitting the spring retainer. It was hitting on the edge by the arch of the rocker. I didnt take them for reasons but i pulled a push rod out and it was chewed up a little bit on the stem(near where it goes through the guild plates).
All the dumb stuff i did:
didnt presoak the hydraulic lifters (then adjusted valve lash) used stock rocker arms, used stock exhaust manifolds,
no smoke out exhaust. so i figure bottom end isnt the problem. it deffinetly looks like a valve train problem. so does anyone know about these heads. i dont really see how the rockers could be hitting both the valve cover and spring retainer. will roller rockers fix this problem. and are the valves hanging open or do they have way to much lash since i didnt presoak the lifters before i adjusted valve last.
Old Sep 14, 2010 | 06:57 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: new 383 i built has problems
Pre-soaking the lifters can cause the valves to hang open, so I never do it. As for the rest of it, I'm too tired to think. I'll read this again in the morning.
Old Sep 14, 2010 | 08:00 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Check your pushrod length since you know you have too much lift. If you are reusing 305 roller cam pushrods they will be a different length than flat tappet pushrods. Also make sure your heads are setup to to handle the camshaft lift you are running.
Old Sep 15, 2010 | 07:31 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
No, it's not too much lift. It's trying to use stock rockers with larger springs. And you need hardened pushrods. As for the valve covers, you might have them outer edge in. They can be installed wrong, and sometimes you can't tell just by looking at them.
Old Sep 15, 2010 | 07:32 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Those heads use self aligning rockers or do they need guideplates like most aftermarket heads?
Old Sep 15, 2010 | 10:47 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
I guess your correct if they are hitting the retainers. I thought they were hitting the guides.
RazorN8
Jan 7, 2022 11:44 AM
mhatfield 14
Oct 24, 2015 07:48 AM
Mickeyruder
Sep 2, 2015 02:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
