Bad to run a little extra oil?
Old Sep 16, 2010 | 08:34 PM
cprepared125's Avatar
Car: 85 Z28 scca C Prepared
Engine: 5.7 348 RWHP
Transmission: t5
Axle/Gears: dana 44 3.41
I have one race to do this year and I have an extra capacity oil pan waiting to go in the car next year but with my new motor I'm a little worried because it takes so long for the oil to drain back to the pan. It's an autocross car that spends lots of time in the high rpm range and I'm just worried it'll suck the pan dry before it drains down.
Old Sep 17, 2010 | 06:40 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Bad to run a little extra oil?
You could get windage, and that could hurt your bearings. But running too low can seize the engine. If you're willing to check all the bearings this winter, then add another quart. I'm usually not one for trick oils or additives, but I think you're a good candidate for Lucas or Amsoil. It's not much cost, and it sure can't hurt.
Old Sep 17, 2010 | 09:41 PM
slowpoke's Avatar
Car: 1987 Z28
Axle/Gears: 273 Limited Slip
It can be. Depends on how much extra. If you put in to much oil, it can be aerated by the crankshaft. But if you are running a windage tray, it may keep the air bubbles down a bit.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Reddeath210
Oct 6, 2015 08:20 AM
InfinityShade
Aug 22, 2015 08:00 PM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
