Horrible vibration below 1k rpm 89 GTA with 357 stock
Old Sep 16, 2010 | 09:08 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Picked up a 357 awhile ago, broke it down to the block to inspect and replace gaskets. Everything looked to be good. So put new gaskets and put back together correctly. Had a few problems with flex plates, one i used a impact wrench on, another i used it as leverage when i got a socket stuck in my crank. Both were wobbling while car was running. Finally got one on there right and runs straight as day. However, when the car idles below 1krpms, it shakes so bad your teeth could chatter. Above 1krpms and even driving, the car rides smooth and performs healthy and strong. I did notice my harmonic balancer wobbling but found that not to be my issue. What am I missing? Any ideas or suggestions would be great!
Here is a video of it starting up. The rattling is from the loose hanger from my left side muffler. Engine would shake so much that's all you hear.
http://www.youtube.com/watch?v=DmTWhLBlx4w
Old Sep 17, 2010 | 04:59 PM
Re: Horrible vibration below 1k rpm 89 GTA with 357 stock
Anybody got any ideas?
Old Sep 17, 2010 | 11:57 PM
Old Sep 18, 2010 | 06:35 PM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
Originally Posted by hydrolic144
mine has dont it since i got the 416 heads installed... not to bad but does get on my nerves... i would not worry about it to much
Old Sep 19, 2010 | 07:07 PM
Car is fixed! Was just a simple carb tune and from setting up my distributor, I fouled my plugs so one of them is missing. Other than that she's alive!! Thanks for the input toolegit86
Old Sep 19, 2010 | 10:19 PM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
sweet glad to see its fixed..
roysatikas
Sep 22, 2015 08:15 PM
cstrobel65
Sep 16, 2015 11:54 AM
Americanmouse
Sep 7, 2015 12:10 PM
JETHROIROC
Sep 27, 2001 09:56 AM
Quiet Bob
Mar 17, 2001 08:21 PM
