cut wires?????
Old Sep 17, 2010 | 05:16 AM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
Transmission: 700r4 stock
cut wires?????
I have a hacked car not real bad just enough to make the car interesting. We went under the steering column to fix the brake lights and then after fixing the broken switch the temp gauge stopped working. I un hooked the sensor between the 1&3 cyl. checked for power with test light. the sensor was getting power. I grouned the green wire at sensor and the gauge had no response.
went under dash I got 4 different cut HOT wires. Brown/white stripe, Grey,brown, and a clear it looks like someone put that one there for some reason.
I got a Yellow wire that looks like after VATS was bypassed tthey connected to a yellow wire and took it to a I guess a junction box with a Red,Blue,and Black wires that are cut and don't go nowhere. all these wires a big and a good size gauge.
I connected a ground to the battery and touched it to each one of the HOT wires. and instead of being pegged straight down it got pegged straight up (it moved) but I dont know which wire made it move my Son wasn't paying good attention.
What color is the wire coming FROM the gauge in the DASH to under the steering column? tell me that and I will find the HOT that it is supposed to be connect to. I know it is a HOT that is only HOT when the key is on.
help!!!!!!!!!!!!!!!!!!!
this and the turn signals is the only thing stopping me from driving the car. Darn expert electrical engineers.
89 305 v8 rs 700r4 ttop
Old Sep 17, 2010 | 11:08 AM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
Re: cut wires?????
can anyone help?
Old Sep 17, 2010 | 11:27 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: cut wires?????
This might help - wiring diags for almost everything: http://www.austinthirdgen.org/index.php?pid=19
Old Sep 17, 2010 | 04:21 PM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
Re: cut wires?????
hey newbie thank you so much I think the wires that are hot go to the fog lights and the rest i will figure out thank yo uso much!!!!!!!!!!!!!!!!!
Jeremys87
Jul 14, 2022 09:08 PM
Caspar
Jun 19, 2016 11:19 PM
mhatfield 14
Aug 15, 2015 10:47 AM
apie2546
Aug 8, 2015 07:12 AM
