fuel filter wont stop leaking
Old Sep 18, 2010 | 11:03 AM
my27kgame's Avatar
Car: '86 Iroc-Z, '98 A4 Quattro
Engine: 5.0 TPI
Trying to change my fuel filter but it wont stop leaking. already caught about 12oz of fuel. is there something i dont know?
Old Sep 18, 2010 | 02:04 PM
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
Re: fuel filter wont stop leaking
make sure its not cross-threaded.
Old Sep 18, 2010 | 02:05 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
As i recall thoes fuel filters have that strange flare (the technical name eludes me at the moment) with the o ring on them correct? Make sure the o ring is in good shape or if in doubt just replace them.
Old Sep 19, 2010 | 03:41 PM
upandcoming's Avatar
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
oring will do it every time
Old Sep 19, 2010 | 03:55 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Did you relieve the pressure at the Schraeder valve? You have to relieve the pressure or the tank will just drain alot.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
