distributor question need help
Old Sep 19, 2010 | 08:43 PM
ponykiller1187's Avatar
Car: 1987 camaro iroc z
Axle/Gears: stock
hows it going i have a 87 iroc and i just put a newer motor in it and i was wonder do i just drop the distributor in or do i have to spin the motor or something. someone told me to just put it in and hook the wires up in the firing order.
Old Sep 19, 2010 | 09:47 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Re: distributor question need help
Don't we all wish it were that easy. You have to hand turn or bump the engine over till you are on TDC on piston #1. There are many methods to figure this out. But once you do that, the point on the distributor should be pointing towards cylinder #1, you want to, from that point, start on that cylinder and follow the cap around with the wires.
Old Sep 19, 2010 | 09:58 PM
Axle/Gears: stock
thank you i actually tried that someone told me to put a rag in the number 1 cyl and i cranked it till it popped out and then someone said were ever the tip of the rotor is pointing thats were i start off
Old Sep 19, 2010 | 10:02 PM
They were right. Some use screwdrivers, others use their finger and plug the hole, have a passer by turn the engine over till they feel compression and their finger is pushed out. But you are on the right track. Let us know how it turns out!
Old Sep 20, 2010 | 12:34 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It HAS to be the compression stroke, not the exhaust stroke. Hold your finger over the spark plug hole for the #1 cylinder, and feel for the air pressure building as the motor is turned over - when you feel pressure buidling and you are close to zero on the timing tab/mark, then that's the compression stroke - turn it until you are at TDC. Then stab the distributor - most folks stab it so the rotor button points towards #1 cylinder as a reference. Then attach plug wire to the post closest to where the rotor points, and follow the firing order around the dist. with the rest of the plug wires.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
beastin91rs
Oct 9, 2015 07:38 AM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
