Oil Pressure guage not showing pressure
Engine: 305 TBI
Transmission: 5 Speed manual
I know there is oil pressure but how do I tell if it is the sending unit or the guage that is not working
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Re: Oil Pressure guage not showing pressure
Have you checked to see if your unit is hooked up? What does the gauge do when you turn the key to the "ON" position?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Grounding the guage wire should peg the guage all the way one direction or the other when key is on.
If you have the OPSU with 3 wires, make sure you don't ground the wrong one - one of the 3 comes from the battery and is a +, the 2nd runs to the fuel pump and is a +, and the 3rd works the guage which should be a ground.
ambainb
Apr 25, 2016 09:21 PM
Navy8125
Aug 21, 2015 09:32 AM
