What springs for small cam upgrade
Old Sep 20, 2010 | 10:03 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I'm going to be putting a used crane powermax grind (2032 I think it's called - 214/220 452/465 112) in my roller lo5, not a big cam but should be an improvement over the peanut cam. The engine has less than 80k on it, I'm not even going to take the heads off. (Budget upgrade) Do I definitely need new springs when I swap the cam? What valve springs should I buy? Anything else I need to change when doing this?
Old Sep 20, 2010 | 10:06 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: What springs for small cam upgrade
The 98111 springs from www.competitionproducts.com would be fine for your combo. They're about $28 / set.
Old Sep 20, 2010 | 10:16 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
They say they are for flat tappet, does that make a difference?
Old Sep 20, 2010 | 10:18 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
they have more seat pressure than stock LT1 springs, and ALL LT1s were HR, and good to 6200 rpm. Is that enough reassurance for you?
Old Sep 20, 2010 | 10:29 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
I don't know...I don't know much about valvetrain at all, I'm kinda flying by the seat of my pants here. Never pulled a cam out or disassembled a valvetrain. Right now I'm accumulating parts so I have what I need when I start taking it apart.
Old Sep 20, 2010 | 10:36 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Valvesprings lose tension over time. You can't see any wear, but they are considered wear items. And at less than $2 each, it's cheap insurance.
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
