intermittent Code 32
Old Sep 21, 2010 | 10:00 PM
87camaroPOS's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Hey guys, My 87 Camaro 5.7 liter TPI will ocasionally throw a code 32 at me. The tube that connects to the catalytic converter had snapped off and I welded it back on a few days ago, could this be the cause of the code? If so why wouldn't it flash the code until just now?
Old Sep 21, 2010 | 10:07 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
Re: intermittent Code 32
Code 32 in that year is EGR circuit. Check all the lines on the solenoid and EGR valve. If you have no driveability or emissions issues I wouldn't worry about the code too much.
Old Sep 21, 2010 | 11:31 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello 87camaroPOS!!
Check the wire to the diagnostic switch under the plenum, at the base of the EGR valve, and see if it looks broken/just hanging on!!
Also check what "thewizard" said!!
P.S. Be careful with the wire, if it ain't broke.......well you know the rest!!!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
Reid Fleming
Oct 10, 2015 09:56 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
