GMPP High Rise intake Hood clearance?
Old Sep 22, 2010 | 09:54 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
I found a deal from a guy locally on this manifold so I'm going to pick it up in a couple hours from now. I need it to match the Vortec heads I already have. I guess this is the same manifold that comes on the 385 Fastburn engine. Does anyone have any experience with this manifold and a stock hood? How much clearance will there be with a TBI and adapter plate on it? I also have the open element 14 x 3 which I think I may need to lose when I go to this setup or play with the drop base.
GMPP 12366573
http://www.jegs.com/i/GM+Performance...66573/10002/-1
Thanks!
Old Sep 22, 2010 | 10:31 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: GMPP High Rise intake Hood clearance?
Should fit. I have a Victor Jr., Demon carb, and 2" drop base with 3" filter and it fits under the stock hood. I have solid motor mounts and Spohn tubular K-member also, I'm not sure if that puts the motor 100% in the same spot or not though.
Old Sep 22, 2010 | 04:13 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Thanks for the input. I picked up the manifold and it doesn't look too much taller than the stock one. I also have a pair of solid mounts as well which will probably go on before I get around to the top end upgrade. Right now my wingnut on the air cleaner hits the hood insulation. The intake is like brand new and I couldn't pass it up for $100.
Old Sep 23, 2010 | 03:23 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
That will work with the right air cleaner. Edelbrock and most of the 'parts store special' chrome 14x3 drop-base air cleaners have around a 1.5" drop, and that should be adequate. Just make sure the base of the air cleaner you buy has the dimples to clear the float adjustments on a 4150/4160 Holley if thats what you planned to use. Most do, but not all.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
