Needing to switch column
Old Sep 24, 2010 | 09:41 AM
twobuy212's Avatar
Car: 1991 Z28/2010 RS
Engine: 5.0 TPI/
Transmission: 700R4 w/B&M Stage 1
I need to replace the steering column in my '91. Can I use a column from a '86? I haven't found any solid answers to this. What are the best years to swap? '89-'92?
Old Sep 27, 2010 | 12:05 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I believe the answer is it will fit, but you'll need to switch over things like the VATS stuff.
Don't you have an air bag? Sorry, I'm not all that up on the later 3rd gen years.
Old Sep 29, 2010 | 02:18 PM
twobuy212's Avatar
Engine: 5.0 TPI/
Re: Needing to switch column
Ya there is an air bag involved.
Old Sep 29, 2010 | 02:44 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Older non-airbag column will bolt up - but airbag and VATS will be an issue.
Better check with local inspectors - might have to keep an airbag in place for safety inspection. If so, I think your airbag steering wheel will bolt on fine, might have to do some collar trimming for the different wheel. And of course you'll have to snake a few wires up through the older column for the airbag to make it functional. However you could just bolt the air bag wheel on non-functional, and remove the dash light for the airbag and no one would ever know (until that freak accident).
On VATS - you'll have to bypass the VATS on the dash side. I'm not sure, but I guess it's feasible to swap your key cylinder to the older column, snake VATS wires up through the older column and reconnect your VATS.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
Bull86
Aug 10, 2015 05:43 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
