Lets play a game (305 TPI)
Old Sep 26, 2010 | 10:17 AM
Kebos86's Avatar
Car: 1986 Trans Am
Engine: 305 T.P.I
Transmission: TurboHydramatic 700R4 4 speed autom
Axle/Gears: ?
1: ?
2: ?
3: ?
4: ?
5: ?
A: ?
B: ?
What are they ? Where do they attach ?
I stripped down the upper and front engine to replace gaskets and o-rings last year. It's sad but I am just now getting back to reassembly and I am a novice. I have a good idea how vacuum and emissions go back together. Not sure where A & B plug though. Definetly could use help. Thanx
Attached Thumbnails Lets play a game (305 TPI)-ta_1.jpg   Lets play a game (305 TPI)-ta_2.jpg
Old Sep 26, 2010 | 10:28 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: Lets play a game (305 TPI)
1. Connects to the breather tube on the passenger valve cover.
2. Should run to the charcoal cannister.
3. I think is the line that goes to the egr solenoid.
4. Emission hoses run there but not sure how.
5. Same as 4
A. Should go down to the sensor at the front of the intake manifold.
B. Should also go to the one sensor at the front of the intake manifold.
Old Sep 27, 2010 | 04:04 PM
jac113's Avatar
Car: 1992 Camaro
Engine: LB9
Transmission: WC T5
Axle/Gears: 10 Bolt - 3.42
let me know if you need more help on this. I just had to do this because my mechanic bailed on me after taking my heads off. I know my way around chevy's but was knew to tpi's before this. I just finished mine about two weeks ago and can send you pics
Old Sep 27, 2010 | 05:00 PM
Kebos86's Avatar
Car: 1986 Trans Am
Engine: 305 T.P.I
Axle/Gears: ?
Thanks for the help guys. I'm going to check it out this week. I'll take another look at it now I have a few pointers, system isn't crazy complicated but just cluttered. JAC113 pics would be awesome, I'll definitely let you know.
Old Sep 27, 2010 | 08:48 PM
Kebos86's Avatar
Car: 1986 Trans Am
Engine: 305 T.P.I
Axle/Gears: ?
85IROC-Z, After reading your post and looking at it a second time it came back to me. Finished putting it back together in a few minutes. Need to replace a couple rotted vaccum lines off the canister and that should be all. After an oil change this weekend I'll try and start it for the first time in a year. Finally see if I know what I'm F#@n doing.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
