bad starter relay?
Old Sep 26, 2010 | 05:38 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
bad starter relay?
i have an 89 305 tbi.the car always starts when its cold.after driving a while on a hot day it won't start.not even a click.ive added a wire to the switch terminal of the starter.touching the wire to the positive side of the battery will start the car when the ignition switch won't.i replaced the starter solenolold.no difference.before i buy a 19 dollar relay anyone have any other idea of might be the problem?
Old Sep 26, 2010 | 06:38 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Re: bad starter relay?
U could bypass the relay
Old Sep 26, 2010 | 08:05 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
But before you do ;
when no crank occurs you should put a DVM on the starter circuit and follow power through to where it " disappears".
Could be Ign switch , neutral / clutch switch or relay at fault
Old Sep 26, 2010 | 08:10 PM
juanillox8's Avatar
Car: TOO MANY
Originally Posted by vetteoz
But before you do ;
Aaah yes, the test, i always skip that step lol
Old Sep 26, 2010 | 10:34 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Cheaper than throwing parts at a problem until you cure it
by elimination
my86bird
Oct 23, 2015 12:20 PM
TheTraut88
Sep 11, 2015 05:16 AM
greenyone
Sep 2, 2015 03:39 PM
RyanJB
Sep 2, 2015 01:27 PM
5spdcamaro
Aug 28, 2015 02:12 AM
