some1 plz tell me whats going on!
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
ok 92 rs camaro 305 tbi/auto
the problem(s):
misfire
running rich
cuts off when hot, sometimes starts right back up, other times needs to sit for a little
things fixed:
new dist
new control module
new coil pack
new injectors
new fuel filter
new fuel regulator
new tps sensor
new idle air valve
new vaccum lines
timing correctly ajusted
new plugs propley gapped
new wires
new cap
new rotor button
suggested things:
something electrical
egr valve
so ideas? ask if you need any more info. please help me fix this, its starting to get real troublesum for me and since its my only car...i need it to run like new-ish. thanks for any and all help.
the problem(s):
misfire
running rich
things fixed:
new dist
new control module
new coil pack
new injectors
new fuel filter
new fuel regulator
new tps sensor
new idle air valve
new vaccum lines
new wires
new cap
new rotor button
suggested things:
egr valve
Andrew Prakash
Sep 8, 2015 11:48 AM
IROCZTWENTYGR8
May 28, 2001 09:30 PM
IROC-ZTWENTYGR8
Jul 23, 2000 02:13 PM
