how hard or expensive to replace a STEERING RACK
Old Oct 1, 2010 | 07:26 PM
hasty88-and-89's Avatar
Car: 89RS-5.0/88IROC-Z-5.0/92-5.7 z28/v6
Engine: 5.0/5.7/2.8
Transmission: 5 spd in two stock auto in other tw
Axle/Gears: stock
wanted to kno b4 i purchase this vehicle how much money is entaild when replacing the steering rack
Old Oct 1, 2010 | 09:54 PM
Damon's Avatar
Re: how hard or expensive to replace a STEERING RACK
It's super cheap and very easy since 3rd gens don't use one!
Just a steering box (3 bolts hold it to the frame, 2 hose line connections that unscrew out the top, one bolt for the rag-joint slip collar connecting it to the steering shaft and the ball joint-type connection that holds the pitman arm on the bottom of the steering box to the centerlink- which you pop apart with a pickle fork after removing the retaining nut). They're not very expensive- certainly much cheaper than a rack-and-pinion style steering rack and much easier to replace. If you buy a salvage yard steering box it will usually come with the pitman arm still attached which saves you the serious PITA of having to swap the pitman arm to the output shaft of a new box (which requires a special pitman arm removal tool and a lot of elbow grease- eat your Wheaties before tackling that swap!).
You'll usually find that the idler arm on the other side of the frame is shot as well on most cars that haven't seem much service. Beyond that it's a "check and see if there's any play" for the rest of the steering/suspension parts to see if they need replacement. (ball joints, tie rod ends innner and outer).
Old Oct 1, 2010 | 09:58 PM
Engine: 5.0/5.7/2.8
Axle/Gears: stock
bout on a 83 VW RABBIT
Old Oct 1, 2010 | 10:04 PM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
Might i suggest..
www.thisisthirdgendotorgnotjunk83rabbit.com
In this day and age, why is it nobody searches? REALLY, 99% of the time you find the answer you need instantly.
But really, who comes on a thirdgen dedicated website, asking how to change a rack on a 83vw rabbit?
Who actually puts money into a vw rabbit? haha.
Old Oct 1, 2010 | 10:12 PM
Damon's Avatar
What's a VW Rabbit? For that matter, what's a VW? There are only 2 brands of cars that we are aware of: GM, which built the super-awesone Camaro and Firebid, and Ford which built the Mustang (which we all rightly hate becuase it sucks- and don't even try to say it doesn't becuase we all agree it does).
Don't come in here and tell us there are more brands to consider because we can't accept that and will hate and shun you (probably throw you off the board for good measure) There is Ford and there is GM. That's it. Choose your side. You should know this already sincve you own several 3rd Gen Camaros.
Perhaps you are suffering from a gas leak in your house. You should get out now and call the local utility company. Further exposure could prove fatal. We only mention this becuase we care about our board members, even those who have the misfortune of owning a VW.
Old Oct 1, 2010 | 10:13 PM
Engine: 5.0/5.7/2.8
Axle/Gears: stock
i was just trying to see how much it would be to replace it
this is the only website i kno with mechanics who have good advice
i know i was in the wrong posting in the first place ( im sorry)
Old Oct 1, 2010 | 10:15 PM
Engine: 5.0/5.7/2.8
Axle/Gears: stock
v6 camaro is sold
ive been looking for a fun replacment
even though probly not going to be better than a gas saving camaro
Old Oct 2, 2010 | 03:54 AM
Engine: 5.0/5.7/2.8
Axle/Gears: stock
while on the subject u consider saab after 1990 to be GM
Old Oct 2, 2010 | 09:29 AM
Damon's Avatar
No.
Old Oct 2, 2010 | 10:24 AM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
It all depends on were you get the rack. Look to spend about 200 dollars or more. It is a straight forward change out job excapt the alingment. But I highly recomend you find a VW board. Here we deal with anerican cars and as you can see GM.
Old Oct 9, 2010 | 05:54 AM
Engine: 5.0/5.7/2.8
Axle/Gears: stock
i kno and do appreciate every bit of info anybody gives me even if its not on camaros
BUT I WILL NOT TYPE NO MORE BOUT OTHER CARS ON THIS WEBSITE
Vintageracer
Jan 10, 2020 05:33 PM
ChevyZ71
Aug 13, 2015 07:30 AM
mizz0313
Aug 12, 2015 06:45 AM
mustangman65_79
Aug 9, 2015 03:00 AM
