Replacing Fuel Filter On 86' Firebird???
Old Oct 2, 2010 | 10:51 AM
lighthorseozzy1's Avatar
I am wanting to change my fuel filter, but have a question, on when to change it, when I have a full tank of fuel. Should I raise the front end, so gas goes toward the back or does that make no difference?? Anyone please answer soon and thanks.
Old Oct 2, 2010 | 10:56 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Re: Replacing Fuel Filter On 86' Firebird???
it won't make any difference. whatever is in the lines will drain out but you shouldn't have any more than that.
do yourself a favor and soak the fittings with PB blaster a few times a day for a few days before you try to remove the filter.
Old Oct 2, 2010 | 10:58 AM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
Same as above and use line wrenches ONLY do not use regular open end at all.
Old Oct 2, 2010 | 11:01 AM
Engine: 450HP 355
Transmission: TH350
agreed, forgot about that. very important.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
92camaroJoe
Aug 13, 2015 06:07 AM
