where do i put my holley blue pump
Car: Blue 84 z28/Cyber 2010ss/rs
Engine: Dart headed, 12:1 355- 510/530 cam
Transmission: TKO 600 Lakewood Bell
Axle/Gears: Richmond 410 Spooled
car is carbed and has stock tank with return line,, alreaty got the reg. with the return in it , pls help me out new motor is here and it wont star with out gas lol Sean.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: where do i put my holley blue pump
Electric pumps push better than they pull. You can mount it under the car on the driver's side over the diff where the fuel lines are.
The blue pump needs the regulator which can be mounted anywhere under the hood but it doesn't need a return line. The blue pump will run fine with a deadhead regulator.
The blue pump will run fine with a deadhead regulator.[/quote]
ok thanks , i looked under the car where the lines run down the driverside ; now is the 3/8 line the one i need to plum in to??
thanks alot man Sean
what should i do with the return line under the hood, plug it? / just leave it or complely remove it, cuz i need to do this now
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I put mine directly under the fuel line. The 3/8 fuel line is the feed line. The 5/16th is the return line. Make sure you hook them up right.
) I ran one rubber line from the line from the tank to the fuel pump "in" side, then the out of the fuel pump to the 3/8 line that goes to the engine bay. I then put the regulator in the engine bay. The return of course goes to the return. Once you get the fuel pump in, make sure you use one of the painless relay kits just in case you get a voltage spike so you won't fry your fuel pump. I've got mine hooked up so when I turn the ignition "on" the pump comes on. This helps prime the system. Hope this helps! Thread Starter
thanks alot man , it all makes sense now.
9192camaro
16
Feb 3, 2019 12:21 AM
86IROC112
Aug 17, 2015 02:00 PM
