89 Camaro Iroc-Z L98 missed badly now won't start at all
Old Oct 6, 2010 | 02:16 PM
clucas's Avatar
Hi,
I'm new to this forum and it looks like this will be the best place to find some suggestions.
I have an '89 Camaro Iroc-Z with a L98 TPI Motor. I've done quite a bit of work to the motor (ported and polished heads, aggresive cam, new top end and bottom end, complete rebuild, 10 to 1 compression, headers, oversized runners, new distributor, new coil, plugs, wires, etc... ). I haven't driven it much and ran it last year and every time I would drive it there would be a miss that eventually got worse and worse to the point where it won't even start now.
The new engine has approximately 1,000 miles on it and when I pulled the valve covers off I noticed one of the rocker arm studs had pushed out and the rocker arm was WAY loose. Realized I should have put threaded rocker arm studs in when I had the motor built. But I was wondering if this would result in a motor running that bad to the point where it wouldn't start, or if I have other issues.
I still have the original fuel injectors, fuel pump, and fuel pressure regulator, could any of these be more of the problem?
Thanks for any help you can give me
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
matthew911
Aug 12, 2015 09:38 AM
