Heater/AC vents not working
Old Oct 8, 2010 | 08:15 AM
Robb Knight's Avatar
Car: 1989 Firebird Formula 350 TPI
Engine: 5.7 350 TPI
Vehicle - 89 Firebird Formula 350 WS6 (stock)
Heater comes on and work, same with AC. The problem is no matter what I switch the slider to, it comes out through the top vents on the dash.The windshield defroster ones. Why would it do this? Cannot get it to blow air through other vents.
Old Oct 8, 2010 | 10:26 AM
Drew's Avatar
Re: Heater/AC vents not working
Have you done a search?
The dash vents are vacuum operated. When the vacuum system fails, it defaults to defrost. It could be the line under the hood to the engine, or the valves in the HVAC control unit, or any of the plumbing in between.
Old Oct 13, 2010 | 10:22 AM
Engine: 5.7 350 TPI
Anyway I can get some pics or diagrams of where these things are exactly. I would rather start with under the hood. where exactly is it located? Thanks.
Old Jul 15, 2014 | 09:51 PM
Brianbajnuth's Avatar
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
did you fix the problem? i have the same problem and i think it has to do with these two vacuum hoses on the passenger side firewall? but have no idea on where it goes. help please!!!!!!!
86White_T/A305
Aug 17, 2015 12:16 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mizz0313
Aug 12, 2015 06:45 AM
mustangman65_79
Aug 11, 2015 03:17 PM
