intake bolt missing / coolant leak
Old Oct 8, 2010 | 08:51 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
who knows how/when this happened but i seem to be missing a bolt. around that, there is coolant puddles. could this coolant be coming from the bolt hole? there also seems to be coolant in the bolt hole. or would this more likely be an intake gasket leak? pic attached.
will these bolts do?
http://www.summitracing.com/parts/MRG-6080/
edit: im not even sure thats an intake bolt?
thanks.
Attached Thumbnails intake bolt missing / coolant leak-snc00157small.jpg
Old Oct 8, 2010 | 09:30 PM
Twin_Turbo's Avatar
Re: intake bolt missing / coolant leak
No, that hole is for a clip that holds some emissions lines, specifically the hard and rubber line in your pic. The clip looks like a W and the 2 lines snap into it. The coolant is coming from your thermostat housing or the underside of the TB is leaking.
Old Oct 8, 2010 | 09:35 PM
Diggler86's Avatar
Car: 86 TA
my TB is bypassed so i'll check the thermostat housing..
thank you!
eightsixseven
Dec 16, 2024 01:50 PM
mhatfield 14
Oct 24, 2015 07:48 AM
TheExaminer
Aug 26, 2015 04:59 PM
86White_T/A305
Aug 17, 2015 12:16 AM
