350 to 305 parts interchange
Car: C4 Corvette
Engine: l-98
I have a lot of parts from my '90 L-98 Corvette and a friend of mine
would like to use some of them in his '87 IROC Z-28 with 305 engine.
I'm mostly interested if he could use my LPE #219 cam and HR lifters that
go with it. I also have 1.427"OD springs to go with this cam. Can those
be used on 305, with just machining spring seats (like in 350)?
Are intake gaskets the same? I have a spare FelPro 1204.
What about TPI base/runners/plenum? Will they fit 305?
Thanks!
Thanks!
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 350 to 305 parts interchange
Yes, that will all work, as long as his 87 305 is finished for a factory roller cam. The 305 and 350 are externally identical.
Sanjay
Aug 12, 2015 03:41 PM
305, 350, body, compatible, engine, external, gasket, intake, intakes, interchange, interchangeability, motor, motors, parts, vs
