Bad distributor or starter?
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
When hot, my 86 Z28 will sometimes act like it has starter heat soak or too much advance and crank veeeeerrrry slooooowly on the first key turn. If I turn the key back to off, and try to start again, she turns over fast (normal) and fires right up. Is it time for a new starter solenoid, or is my early 70's dizzy sticking with too much advance?
Starter is about a 10-12 year old lifetime warranty Advance auto unit w/ a solenoid heat shield.
Distributor is circa 70's unit with Accel Super HEI, Accel Cap and rotor, Accel ICU, curve kit with 1 light and one medium spring (IIRC), Accel adjustable vacuum can, and a speedway/unilite replacement harness and pickup (http://www.speedwaymotors.com/Stock-...ness,1342.html).
Thanks in advance- no pun intended.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Bad distributor or starter?
Does the cranking speed up when the power is disconnected from the dist?
