400HP 305CI build Is this article real
Old Oct 25, 2010 | 10:43 PM
  #51
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: 400HP 305CI build Is this article real
Originally Posted by Firebirda7x
I thought you could bore a 305 out to a 350, I knew it would not make a very strong cylinder wall though. But yea I don't think anyone says it's economical to go the 305 route, but it is possible to make good power out of one. I just don't know why most of the build ups I've seen have high RPM powerbands...
Most you can get out of the bore is 315ci and at that point id hope you did some sonic tests on the thickness of cylinder walls, sometimes the blocks shift during the casting process and when you max bore you'll end up into the water passages you'd be lucky if you could use liners after a catastrophe like that, LS1 blocks are notorious for core shift during the casting process. It might be economical for some but its not all that practical if your spending more then you would for a lager displacement engine. The higher power band has a lot to do with the bore size, stroke and its displacement, but not limited to the top end or cam, and that's just summing it up. I.E a larger bore diameters has better airflow because the cylinder wall is farther away from the valves so power band can be lower (and that all depends) the 3.736 bore is small and the valves are basically shrouded against the cylinder wall so it has to ramp up to achieve this, keeping a consistent feed of air flow into the intake system the pistons draw more air in on each opened intake lift as the rpm get higher.
tyeo098
Nov 30, 2015 06:27 PM
Formula8r89
Sep 22, 2015 04:24 PM
abray1
Sep 10, 2015 04:53 PM
Street Lethal
Sep 7, 2015 01:09 PM
scotrans am
Sep 5, 2015 04:26 AM
