2.8 starting issues????
Old Oct 18, 2010 | 05:14 PM
GREEK BANDIT's Avatar
Car: camaro iroc-z
Engine: 5.0
hey, i got an 86 firebird that takes a long time to start. sometimes you have to crank it for a good 7 or 8 seconds before it finally fires up. the warmer it is the longer it takes and in the winter it sometimes fires up like nothing. its got me stumped. the car starts every time but sometimes its kinda embarrassing because my friends just call my car junk but then i just point at their sunfires and cavaliers and they usually shut up.
Old Oct 18, 2010 | 05:27 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: 2.8 starting issues????
cold start injector.
Old Oct 19, 2010 | 11:52 PM
donnas88camaro's Avatar
Car: 1988 Camaro
Engine: 2.8
Transmission: auto
I have the same problem. If you hit either in the intake it would start right up. But the next morning it will not start. Would that be the cold start injector? Thanks
Old Oct 23, 2010 | 08:23 AM
Engine: L31 350
what do you mean when you hit the intake?
Old Oct 24, 2010 | 12:38 AM
Car: 1988 Camaro
Engine: 2.8
Transmission: auto
When you spray starting either in the intake, it will start....But will not start on its own.
Old Oct 24, 2010 | 01:24 AM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
That sounds like you don't have enough fuel pressure. Put some fuel injector cleaner in the gas tank, replace the fuel filter, and the fuel pump relay. Those things are fairly cheap and if your lucky it'll be one of them. If none of the above helps the problem then your fuel pump is on it's way out.
Old Oct 24, 2010 | 06:44 PM
Engine: L31 350
or the injectors are on their way out., how long has the car sat?
Cleotiz
Jan 6, 2018 08:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
