small problem...
Old Oct 18, 2010 | 09:37 PM
jfroh1992's Avatar
Car: 91 RS, 93 k1500
Transmission: T5, NV3500
Axle/Gears: stock
small problem...
i pulled my intake off and found this. every pushrod on the passenger side was like this.
the only reason i can think of that this happened is that the cam, lifters, or pushrods are wrong. i have roller lifters but from what i know about roller cams mine isnt a roller. would that cause this to happen?
anybody who can help me please let me know.
Old Oct 18, 2010 | 09:46 PM
jwande's Avatar
Car: 92 Jamaican Yellow Firebird
Engine: 305 TBI
Re: small problem...
I take it this was running? Ouch! Is this a newly rebuilt engine?
Old Oct 18, 2010 | 09:58 PM
jfroh1992's Avatar
Axle/Gears: stock
no it wasnt running. when i got it it needed a fuel pump. after i finished with the fuel pump i went to start it and it dumped oil out. thats why i decided to tear it down.
Old Oct 18, 2010 | 10:03 PM
jwande's Avatar
Engine: 305 TBI
Physical damage suggests something broken internally as you probably figured. My guess, someone didn't know what they were doing and tightened the rocker nuts all the way down tight. Or mismatched components. Just a stab in the dark.
Old Oct 18, 2010 | 10:06 PM
jwande's Avatar
Engine: 305 TBI
Where did the oil dump?
Old Oct 18, 2010 | 10:08 PM
jfroh1992's Avatar
Axle/Gears: stock
it seemed to be coming from the back of the head on the drivers side
Old Oct 18, 2010 | 10:13 PM
jwande's Avatar
Engine: 305 TBI
Behind the intake, behind the head, technically in the block. There is a port where an oil sending unit or a plug goes in. You're right, lots of oil will dump out of that hole! Quite discouraging. You may have an unplugged port or a broken/damaged oil sending unit.
Old Oct 18, 2010 | 10:14 PM
jfroh1992's Avatar
Axle/Gears: stock
ive heard that roller cams have lobes that are kinda oval shaped instead of the teardrop shape. my cam has the teardrop lobes. i know this motor was supposivly just gone thru, but with how much sludge i found i find that hard to believe
Old Oct 18, 2010 | 10:15 PM
jfroh1992's Avatar
Axle/Gears: stock
i have the engine out of it and am going to rebuild it just because i dont really trust what the other guy did
Old Oct 18, 2010 | 10:17 PM
jwande's Avatar
Engine: 305 TBI
Given what you're finding, you should probably pull it and start over. You may be better in the long run. Think of the things you haven't found yet. It is making me cringe for you!
Old Oct 18, 2010 | 10:20 PM
jfroh1992's Avatar
Axle/Gears: stock
its down to a bare block right now and i havent really found anymore problems
NZKnight
Oct 15, 2015 02:47 PM
skinny z
Oct 5, 2015 06:23 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
