number 5 and 7 plug,how to get out?
Old Oct 19, 2010 | 04:39 AM
jdracing's Avatar
Car: 92 RS 5-speed Garnet Red
Engine: 92 RS Automatic White
Transmission: 84 Z28 Automatic Red
Axle/Gears: Top to bottom 3.30, 2.70, 3.70
well,is there a good tool you can buy to get to the last 2 plugs
on an 88 tbi 305?
i had enuff trouble getting the rest of the plugs changed.
it got dark on me,but for the life i couldn't get to the last 2 plugs on drivers side.
any suggestions?
thanks,
jd
Old Oct 19, 2010 | 05:57 AM
cliff1970's Avatar
Car: iroc z
Re: number 5 and 7 plug,how to get out?
go from the bottom side, its still tough but alot easier than going from the top
Old Oct 19, 2010 | 06:46 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
For hard to get to plugs, Ive always had good luck with a little tool I made. I picked up a spark plug socket from advance for $3. Make sure it is one with the inside hex all the way through the socket. I then cut half of the socket off and drilled the drive square out enough for a plug tip to fit through. I now use it to slide onto the plug and use a box wrench to get it out. Works great on tight places where you cant get a ratchet or regular socket.
Old Oct 19, 2010 | 07:15 AM
jdracing's Avatar
is it possible you could send me a picture of it?
probably be easier to send to email address below.
msjdracing@rtmc.net
thanks for the help,
jd
Old Oct 20, 2010 | 11:50 AM
3rdgenmaro's Avatar
Car: 88 IROC
Get one of those, and cut about 1" off the socket side. *Make sure the hex goes all the way down on the inside of the socket*
Then drill out the end so that the plug tip will slide through.
I can try to get you a pic later.
Old Oct 20, 2010 | 12:01 PM
jdracing's Avatar
well,yesterday i got on it before dark and got er done.
i did have to go for number 7 from underneath the car.
it was actually the easiest plug i changed.
there would have been no way to get from top.
now i still have the problem.
when you come to a stop sorta fast engine dies.
seems to have a miss when you first crank before engine gets warm.
sometimes when you punch it the car just looses all power
and service engine soon light comes on.
i have also noticed a hesitation at normal shifting thru gears.
any ideas what problem is?
also,
what gear lube goes in a manual 88 5-speed v8?
thanks guys,
jd
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
gixxer92
Sep 1, 2015 04:32 PM
Thornburg
Aug 30, 2015 08:05 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
