smaller distributer cap?
Car: 84 camaro, 92 yota 4runner
Engine: 305 lg4 out of 81 z28
Transmission: th350
Axle/Gears: Not sure believe its 3.23
do the sell distributor caps smaller than the stock GM AC delco ones? IF so which one is the smallest cap/rotor you can get?
Car: 87 GTA
Re: smaller distributer cap?
The pre-HEI dizzy in cap, separate coil caps are the smallest I've seen. Any smaller & I'd be worried about crossfire.
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Smaller caps have the disadvantage of requirng the terminals to be placed closer together. This increases the chance of cross-firing when spark jumps to the wrong terminal. One of the benefits of the HEI is the terminals are spread farther apart.
Most move to smaller cap distributors for clearance reasons.
Jake
Jake
Transmission: th350
id like it a bit smaller in diamater than stock (84 lg4 305) like mayber 1/4 to 1/2" less in diamater would help alot thanks.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The cap is the same diameter as the distributor so unless you're going to change it too there isn't anything.
Transmission: th350
okay , well if i could have had a cap that changed diameter after it was sitting on the distributor it would of worked to cause its mostly the top part that its hitting but oh well nothing a hammer and grinder can't fix i guess lol
Engine: 383 Carb
Transmission: 4L60
What is it hitting? There should be enough room between even a large-cap HEI and everything around it.
Transmission: th350
well its not in a third gen its hitting i took the engine out of one of my parts car third gen and put it in a toyota 4runner
Damon
Sep 26, 2015 04:29 PM
